Andy
Re: Blistering paintwork, on panel above windscreen.
Further to our telephone discussion of 29 May, regarding the five questions you have regarding the Volkswagen California roof.
I am drafting a response for you to share with your members, however I do require input from a number of colleagues and hope to
have the answers to you by 13 June.
Martin said:Looking at the posts on here and from PM's we have been receiving, the problem with roof corrosion now looks like it is affecting the entire elevating roof aswell as the front panel.
VW Customer services appear to be saying this is not a fault they are aware of.
I plan to chase up my call with them next week and would like to have some information to give them on this.
Before making your choice on the poll please go and and inspect your roof, especially around the black rubber seal on the main roof.
WelshGas said:Would've interesting to know if there is any correlation between wether the vehicle is garaged or not and the incidence of the roof corrosion.
I was told many years ago, leave a vehicle outside or ideally under a carport so that it can dry as quickly as it gets wet. Putting it into a humid garage will just let the rust bug eat it away.
I've never garaged my vehicles since and never had a problem with the rust bug.
Martin said:Just had an update from VW
HY09UMU said:I would echo what Stu stated, I do not yet have paint issues on my front panel but I emailed VW asking what the cover was re this " inherent" manicacturing known defect whilst l did not get a email reply VW phoned up and implied warranties would cover this I would contact VW direct
Mr Smith - Director VW Commercial Vehicles said:Every Volkswagen California comes with 12 years warranty against through-corrosion (corrosion emanating from inside the body panel) and three years warranty protection for any paintwork defects, offering customers complete peace of mind.
Mr Smith - Director VW Commercial Vehicles said:As per my previous correspondence I would like to reassure California customers that each vehicle comes with a 12-year' warranty against through-corrosion (corrosion emanating from inside a body panel) and a three year warranty for any paintwork defects.
Freeley said:Or like in my case a 2009 with no corrosion. Where do vw draw the line I wonder?
Sent from my GT-I9505 using Tapatalk
WelshGas said:Aluminium corrosion takes a number of forms and water is a common denominator in most of them.http://www.aluminiumdesign.net/design-support/aluminium-corrosion-resistance/ However if this is not corrosion then it is probably something to do with the coating/paint process/type used. Even Land Rover's Defender has problems and the aluminium alloy body panels there have not changed for 67 years, but their 6 year Bodywork warranty does cover it.
Will be good to see a comprehensive statement from VW Customer Services.
777111 said:Totally agree.
VW are avoiding making reference to the same problem with the main roof which is suffering the same problem as the front panel.
About time they came clean on this and faced up to their customers.
Stu said:777111 said:Totally agree.
+1
I was told that the reason for the 'corrosion' had been identified as a paint/materials issue therefore it strikes me that if the front panel has a known issue and assuming the roof was painted using the same process it too will suffer, it's just a matter of when it happens. So we will own a ticking time bomb if not repaired within the paint warranty period.
I suggested yesterday the VW should extend the warranty on the affected components. They aren't budging.
