caligraphy
- Messages
- 90
Auto re-tension ? Sounds like VW have introduced a complex solution to a problem that is only there because they chose a complex solution to a problem that didn't need fixing. I can only go on my own experience but my 2007 T5 doesn't sag at all since I lubricated the jacks. It seems that the hydraulics will only lift until a certain amount of resistance is met. That should be when the roof is taut but dry or dirty jacks could stop the roof reaching its ful height. Once full height is reached and unless the hydraulics are leaking it should stay that way. That's my experience but , of course, I'm happy to be challenged.
They won't want to repair it with 6 months left, they will be clamouring to repair it for you after 6 months though!
Without wishing to be rude, ours sags after about 36 hours or so but only on one side - this is actually normal and to be expected.
As we have a. 2011 model, we don't have the auto re tension facility which only came into being around 2013 I believe.
Definitely insist and take it back. I had mine done back in 2012. Good as gold now.![]()
