P
Pete Toogood
Halfords have AdBlue on offer at the moment £15 for 4 litres ( Ha Ha! ) but, more interestingly, £20 for 10 litres ! I expected it to be blue but it is clear ! Must be kosher though from Halfords. Pete
I top up each time I fill up with diesel, simples
Yeah that does seem a bit OTT or at the least inconvenient!Every time?
So 32.5% aqueous solution of urea - £20 for ten litres? Someone is taking the pi$$!Its a metered system based on the amount the engine is driven. This video gives a good overview, the layout is different but the method is the same.
Funny post! Sorry for late reply. As a matter of information the Adblue tank holds 13 litres according to this web site. http://myadblue.co.uk/adblue-volkswagen/volkswagen-california/I have filled up Adblue 5 times - it averages around 4000 miles per fill. The cost seems to be around £12 for 10 litres. I did consider larger quantities, but the tank holds 10 lts so it would mean storing it in the garage - not pleasant stuff. Last fill was in Italy and was available at larger petrol stations. In the UK i tend to buy from Shell petrol station when getting low - seems good value. Its worth keeping a funnel in the van as some of the containers dont include one. You should wash the funnel after use as when it drys it goes crispy and you dont want bits of crispy pig pee in your tank.
I was told that if the tank becomes empty on a Cali the engine will not start - is that correct?As you will now know it is available from most Fuel Stations now. White plastic cans that have a filling flexi pipe attached, looks like a can of water. Be careful as it is very corrosive so wash any spill off. Euro 5 Trucks have had it for a few years now and is injected into the exhaust to clean out the soot. More bits to go wrong. Trucks go into 'limp' mode if Adblue tank empty, to stop emission system not being used, but I haven't seen if VW's do that as well.
Loz, I know you recently took delivery of your new Cali - did you get a full tank of Adblue? Or just a token amount?I hope you didn't buy any diesel it's 1.27/L at Gloucester that would have wiped out your saving![]()
Correct. No Adblue No Engine, to protect the environment.I was told that if the tank becomes empty on a Cali the engine will not start - is that correct?
I got a full(ish) one - said 4500 miles to fill-up; done 3000, still says 2000 to go. I think it depends on the dealer...Loz, I know you recently took delivery of your new Cali - did you get a full tank of Adblue? Or just a token amount?
Cheers JB (Rik)
Can't really tell how full but the adblue range read 4000 miles, have now done 800 miles and adblue range is 3500 miles.Loz, I know you recently took delivery of your new Cali - did you get a full tank of Adblue? Or just a token amount?
Cheers JB (Rik)
No other chemists out there?So 32.5% aqueous solution of urea - £20 for ten litres? Someone is taking the pi$$!
Not concentrated enough.No other chemists out there?
Urea is a chemical that the body excretes via urine...
I don't recommend trying that as a substitute for AdBlue though!
As far as I understand it, the Cali's adblue range is about 6,500 miles, and a message indicated every 60 miles when about 1,500 miles remains in the tank, this increases to a message, warning light and bleep every 30 miles at 1000 miles or less. Once the tank is empty, the engine stops [edit] *will not restart once the ignition has been turned off*. 1L of adblue is good for about 500 miles. If you wait for the first message, you should have about 3L of adblue in the tank, and can then fill up with 10L, the most economical size to buy (Unipart adblue £9.99). The 13L tank and message at 1,500 miles is there for a very good reason, it is not a warning, just a message, 500 miles from a warning, so no shame in waiting for the message to appear.I don't have any experience of topping up Adblue but it seems to me from what I read its a regular check that is needed and if needs be a top up. Is that not the same as tyre pressures, washer bottle, engine oil? I check these things in ANY vehicle on a regular basis (once a month when I wash the car - its like a normal routine, part of ownership) just like all of us should do, so just include Adblue in these level checks and act accordingly. Adblue is widely available and has been used on commercial vehicles for some years now. It can't be that complicated, or am I missing something.
Surely if you have to wee into the tank you'll have concentrated enough!?!Not concentrated enough.![]()
