estresao
- Messages
- 902
- Vehicle
- T5 Beach 4Motion
Regarding the speedo, at the moment it's around 2 miles/h behind the GPS speed, so I guess this size will makes the speedo read more accuratelly (I don't think it will be perfect, but it is not now)
Hi estresao,Thanks HugoFar,
I've already did and 225/65 R17 are the more close to the ones I've got know (BG AT KO2 I mean). They are one cm narrower and diameter is around 3cm bigger, but looks like they will not rub (I made some "investigations"). The bigger diameter will give me a little more than 1cm of more ground clearance.
I think you are reading the table wrong, the table shows what ELSE need to be done except the lift kit. In your case the 235/65 R17 needs Seikel Lift kit AND steering stop limit which gives with changed tires +54mm lift.According to this Seikel document, 235/65 R17 does not require any change, no steering stop limit is required, so I guess it should be safe to fit 225/65 R17
http://www.seikel.de/wp-content/uploads/2015/12/Höherlegungswerte_T5-T6_2015-10_1221_engl.pdf
I am with Kave. Only 235/55/R17 does not necessarily need modification such as lift kit, steering stop or wheel case. Any higher (235/65, 235/70) will need modifications, the way I read this table.I think you are reading the table wrong, the table shows what ELSE need to be done except the lift kit. In your case the 235/65 R17 needs Seikel Lift kit AND steering stop limit which gives with changed tires +54mm lift.
The 225/70R17 requires both lift kit and "short seikel axle transmission".
I dont think they meant to give examples to what to get without lift kits, its marketing to buy lift kits.
However, I am sure the margins on the T5/T6 will allow another size but you probably have to try it out.
The issue is with you speedometer. When the wheels are too big, the speedometer starts to underestimate your actual speed. In most countries that is not allowed. Seikel adapts the settings so that your meter gives the correct speed again.We can only fit tyres that have maximum +1.5% extra circumference. Not sure how Seikel does this. Is Germany less strict? Does the certificate of no objection you get for Seikel suspension or VB Air suspension also apply to the tyre
The restriction is to make sure that Braking efficiency is not reduced as a larger diameter wheels need more energy to stop.Ouch. Yes here in Belgium the law is also very strict. We can only fit tyres that have maximum +1.5% extra circumference. Not sure how Seikel does this. Is Germany less strict? Does the certificate of no objection you get for Seikel suspension or VB Air suspension also apply to the tyres?
Question remains.. how does Seikel get away with the larger wheels? I mean how can they get the legal documents or is germany's TUV less strict on this?
from Seikel's website said:Part certificate from TÜV
We have the appropriate part certificates to ensure that the combination of tyres and wheel rims can be entered in the vehicle documents without any difficulties.
89,25 € (incl. tax)
75,00 € (ex. tax)
Speedo adjustment
- for Volkswagen T5 up to MY 2010
446,25 € (incl. tax)
375,00 € (ex. tax)- for Volkswagen T5 from MY 2011
35,70 € (incl. tax)
30,00 € (ex. tax)
No, I just checked with GPS that our speedometer gives no underestimation. In my understanding that is enough here in NL. There is nothing in the car registration about wheel sizes.bvddobb, did you have to do anything after fitting those larger tyres? Because it looks like a European thing..
