estresao
- Messages
- 902
- Vehicle
- T5 Beach 4Motion
Our winters are ' T5.1 standard size': 215/65 R16. Our 'summers' are slightly larger AT's: 225/70 R16. Their circumference is about 5% larger than 'standard'. But with our 'standard' size winters the speedometer overestimates the actual speed with approx 5%, with our larger summers the speed is exact, cf GPS.@bvddobb, which tire size do you wear? I thougth you were using "standard" size, 235/55 R17 for example.
For information: I have just fitted BF Goodrich 225 65 17 KO2 to our 2015 T5 TDi400 4Motion Transporter pop top - Pretend Cali.
Fitted without any problems. Raised van 18mm (210mm Ground clearance now fully loaded + extra spare wheel.) No spacers, no lift, all standard.
The tyres do not rub anywhere on full lock.
They should be OK with small chains on front (though the chains might rub on full lock). We don't often need chains here in Aus.
The closest they come to being a problem is that the rear tyres only clear the behind inner (Plastic) guard by 16mm, not a lot of room for thick mud builds up.
Note 235 65 17 tyres will only leave 7mm for mud build up on, if van left at standard height!!!!
I am running 45psi all round, steers, rides and turns well.
It is great to have an extra18mm tyre wall height and not be afraid of denting the rims.
Good Luck
PS Yes they are a bit noisy!
Beware of fitting spacers as you will get 'bump steer' and it also can load the wheel bearings. Practical experience of this from way back on cars.Still thinking in BFG KO2
I've had a look to a thread in VW T4 Forum about this subject, and there are people who fitted massive tires.... the ones I want fit looks like biscuits compared to them.
I've found many of them use spacers, which could be a neat solution in my case because I'd go from 235 wide to 225. The point here is how thick the spacers should be to prevent tires from rubbering when fully turned. There are many people wearing 20mm ones, but they are aso fitting very big tires.
Do you think something like that could work? http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=423383
That's the point using rims with smaller ET, no spacers requiredBeware of fitting spacers as you will get 'bump steer' and it also can load the wheel bearings. Practical experience of this from way back on cars.
Bump steer is when a front wheel hits a bump, even a minor one, and the steering wheel turns in your hands needing a correction. If you had an accident the Insurance wouldn't pay out if they hadn't approved of the modification. You could also be prosecuted for driving without valid insurance.
Have you tried a search on the BF Goodrich site for options?
One that seems a good compromise without changing the gearing (upsetting speedo reading) could be
http://www.bfgoodrich.co.uk/gb/rang...in-T-A/(ts)/d::215::60::17::96::H#detail-tire
a bit less tyre width but more if you look at rally cars they go narrower for off road use. Cuts through mud & snow better.
That's why we went for 225/70/R16. Same outer wheel size and extra (2 cm) bottom clearance, but even higher walls still than 225/65/R17.225 x 65 series give a wall increase of 17.25mm over 215 x 60. That is mainly what I was after.
4 motions (at least T5.2+) require 17 inch unfortunately...Have you tried a search on the BF Goodrich site for options?
In Spain's forum there are at leasf two guys whi replaced the brakes for the "normal" ones and fitted 16" wheels.Pity the TDi400 must have 17" wheels to clear the bigger front brakes. There are a lot more options in 16" tyres![]()
That's the easy part, but there's more. I contacted them about it and there are certificates and confirmations from VW necessary. The type of documents you need depends on your national laws. Seikel can supply the documents for the German market only .. Not for Belgium.The legality has to do with your speedometer. You can have other wheel sizes, but then you need to have your speedometer adjusted, so that it's correct within the legal limits. That seems to be easy for the 5.2 . See the Seikel website. They offer this service in combination with a change of wheels/tyres and for the 5.2 the speedometer adjustment is lots cheaper than for the 5.1.
Verzonden vanaf mijn iPhone met Tapatalk
I wonder what the Insurance company said - " so you downgraded the brakes to fit Off Road tyres that have less grip and longer stopping distances on tarmac roads where all the traffic is? "In Spain's forum there are at leasf two guys whi replaced the brakes for the "normal" ones and fitted 16" wheels.
In Spain thing are very different than in UK, you HAVE TO get an official certification for almost any change in your vehicle and pass the ITV (MOT) to be legal. It's by far more strict than in UK. Police chase pretty much ilegal changes, so the smalest concern is what insurers says (providing you are legal).I wonder what the Insurance company said - " so you downgraded the brakes to fit Off Road tyres that have less grip and longer stopping distances on tarmac roads where all the traffic is? "
" Which Funeral Plan would you like to take out, Sir? "![]()
