Some body shops have already tried this but they were told not to continue because it was not part of the VW Approved system.
There is also a photo on here somewhere of bubbling under the tape.
If the tape was properly applied such that it completely isolated the seal from the roof and the corrosion re-appeared, then the seal is not the problem.
is that Sold Californias Unknowingly Mugged?Remember VW are invincible and we are scum![]()
I have an early T6 Beach Dec 15 - never seen a garage with 30k miles of hard use - and at the moment i have no issues to report - i have a non-metallic paint finish on mine and wonder if anyone has suffered the problem with a flat colour ?? white red or yellow ?? maybe the paint problems are compounded by the metal in the metallic paint and maybe the boring colours are the better at resisting the corrosion options - just asking
Only going by what I was told from 2 Dealers, one of whom I trust.So why do VW say end of 2013?
If the tape prevented the area of roof paint under the seal being submerged in water I think it may be a solution. Tape would have to be 100 percent water tight inside and out of the roof to be effective. I think the silicon grease would do the same job. The more I get to know the more I am convinced the water that sits in the seal is the biggest cause of this roof corrosion issue.Shoot me down if this is a stupid suggestion but would it not be possible and beneficial to apply a transparent flexible tape to cover the edge of the roof that is in contact with the seal? The tape would be a few mm proud of the seal and would not be visible being transparent. I have no idea how possible it would be to obtain such a tape but I am sure someone here would know.
I was thinking of vinyl wrap material like 3M venture shield that the front of my cali is wrapped in.If the tape prevented the area of roof paint under the seal being submerged in water I think it may be a solution. Tape would have to be 100 percent water tight inside and out of the roof to be effective. I think the silicon grease would do the same job. The more I get to know the more I am convinced the water that sits in the seal is the biggest cause of this roof corrosion issue.
Water is the catalyst. The cause is the two dissimilar metals, aluminium and steel in close contact that causes the issue. Water on aluminium itself isn't enough. The real culprit is the steel protruding through the seal. Without this the corrosion wouldn't occur. AFAIAA of courseThe more I get to know the more I am convinced the water that sits in the seal is the biggest cause of this roof corrosion issue.
Agree, but the blistering may still occur as a result of the simple prolonged submersion of the paint in water.Water is the catalyst. The cause is the two dissimilar metals, aluminium and steel in close contact that causes the issue. Water on aluminium itself isn't enough. The real culprit is the steel protruding through the seal. Without this the corrosion wouldn't occur. AFAIAA of course
I agree. I seem to remember VW saying this at the time, but there are so many posts it will be difficult to find.Only going by what I was told from 2 Dealers, one of whom I trust.
Maybe OT here in this T6 thread, but that was exactly the opinion of our dealer Campercentrum in Amersfoort (NL), who repaired our T5.1 (2009) roof two years ago. It's water ingress between the alu roof and the rubber sealing, together with dirt and sand underneath, that "sands" the laquer, and leads to electro-chemical blisters, he told us.
Against the new rules of VW Hannover he taped our roof around the the edges, inside and outside, under the rubber.
VW had forbidden this practice, demanding that the roof should be sealed against water by glueing the rubber seal tight on the aluminum edges.
Glueing does not prevent the sanding of the lacquer against the rubber, says our dealer.
Time will tell.
In the mean time we keep smiling every day we're on the road with our wonderful travel capsule.
Blisterfree greetings from Amsterdam,
Marc.
Hi,
Thanks for sharing that with us, do you ever remove the seal to check underneath?
I would be very interested to see an independent bodywork specialist's report on what the has caused the corrosion.
And I'm sorry but the sanding effect sounds like typical VW BS. If the roof rubs around that much in the seal you would be able to see the rub marks. Some folks have shown lines on their roofs but not rub marks.
