AlanC
Traveling
Sorry, I don’t understand your statement.Not true. Just a lot of people in denial.
In denial about what? There is a oil consumption problem on 180 engines, or the dates I stated?
The early problem was just 2010-11 engines as I spoke to VWUK at the time as was told this. Other years are affected but not to the same degree as far as I can tell and may be not for the same reason, ie the alloy corroding inside the EGR.
The latest D suffix EGR seemed to solve the issue as it had a coating on the inside to prevent the corrosion. It is possible that this coating can weaken or not be applied properly in manufacture so that the corrosion reappears. Only VW Germany will know.
It only affects engines with the alloy EGR. The rest of the range have a different EGR made from Stainless Steel I believe. Happy to be corrected on that.
Alan
