Sp0_0k
- Messages
- 1,247
- Vehicle
- T6 Beach 4Motion
How bad this corrosion can go if just left unattended?
Like will the roof leak in 10 years?
There are some 08 vans still watertight that contain calirotHow bad this corrosion can go if just left unattended?
Same as yours..late 2014↑
Just got my T5 back....no corrosion, tape applied
What year? as they have been making T5's for some time.
I'm sure you have read the previous posts from Nos: 263 onwards?My 2014 T5 has had the roof repainted and a new seal bonded to the roof in October 2017, anyone else in the same situation who has subsequently had a recall to have the tape added after the bonded repair?
Not sure if I would want the bonded seal removed unless a proper repaint of the roof edge was carried out.
The Workshop Recall goes back to 2010 I gather. My 2014 was done at my last Service. They won't call you, but would do it on your next visit unless you book it in specifically. I would ask VWCS for their advice.I had, my question was was T5 related as there has been no actual recall for the T5 roof issue as far as I know?
I can't see it being more than 2 hrs tops. Had mine done during a major service + cambelt and brakes.Can someone advise how long is the process to remove the seal and apply tape and refit tape if no issues found?
Ours is a T5.I had, my question was was T5 related as there has been no actual recall for the T5 roof issue as far as I know?
Probably won't order the Tape in until the roof has been checked.Exactly Just book our van in for the second service - asked about the roof check and was told dealer wanted 2 days for this. This was a receptionist so will pop into and speak to the service manager when passing.
I'd say if the dealer says he needs 2 days, take it. Ours was in for 1 day for timing belt and water pump and 4 year service as well as the roof check and OK the roof check was botched because the seal had been bonded on but I think if they'd had 2 days, they might have realised the issue, taken their time and done a proper job. Having said that, if the seal has been bonded on then it needs a new one as the only way to get it off is with some force which knackers the old one.asked about the roof check and was told dealer wanted 2 days for this
I didn’t get it back for 17 days.
I agree. It took another two weeks last November to sort out the bubbling under the seal but they also did the cap replacement at the same time because some front roof panel corrosion had appeared, despite the fact that it should have been cured in 2014. Everything seems fine now but I expect that mine will still be subject to the recall for checking under the seal/applying tape. I would be more than happy with two days for that at a VW dealership as opposed to transporting it to an approved body shop for the third time.The original reair on our T5 was under 2 weeks door to door - with a replacement new Cail via VW UK. Removal of the front cap and replaced with new metal one and repair of the main roof. On our T6 I am only looking at a check under the seal and tape application. If it requires paint job then it takes as long as it takes. I personally would not be happy with the current repair if our old T5 had to have the full works undertaken with the cover-up cap being commissioned by VW today.
That's a creative excuse!! Masking tape took the paint off!! Serious masking tape that... I'd guess either they caught it with something or there's an underlying issue on the original painting of the roof during manufacturing.When applying the tape they managed to lift off some of the roof paint with masking tape they were using in the process.
Eh? You just posted in it.. go back to page 1of this very topic and get yourself a cuppa and have a good read.I am a bit confused - our 2012 Cali had its roof and roof panel done in 2014ish one of the early ones where you got a full replacement of stuff and repainting etc etc...
now dealer tells me it has to have something done under VW recall
I have searched but am not good so can anyone point me in direction of threads about what this exactly is for ones like mine?
Servicing desk guy is a bit vague re specifics?
