SusiBus
2-pedal power Peppa Pig trike
No, wish it was because I think it is a very useful upgrade.I'm sorry l should have written March 17 Calli
My March '17 has tape factory fitted.Up till now I've had my head truly buried in a bucket of sand. Wishfully thinking/hoping that having a March 17 Calli "with tape" it would be one not to suffer the dreaded roof corrosion, but now reading that a November 17 has been found to be suffering roof pox, the Dilemma now is, "To check, or not to check"!
When will this Saga ever end, I guess probably not until the T7 at the earliest.
There is no bare metal, it is moulded in the rubber seal.I've decided against removing the rubber the reason being that if the rubber has a faulty metal gripper it would potentially tear the tape and paint underneath, which would defeat the object of the tape.
Unless it peirces the rubberThere is no bare metal, it is moulded in the rubber seal.
From the information I've gleaned on here it's the bare metal protruding through the rubber seal that causes the corrosion. No bare seal metal contacting the roof alloy - no corrosion.There is no bare metal, it is moulded in the rubber seal.
I haven’t got an isotop but they definitely removed the bellows- they then renewed them as they said they had damaged them during removal. I’m not sure whether the new repair entails removing the bellows.I took my T6 in today to have the tape applied. They checked it a couple of weeks ago, found no corrosion, but had no tape. They told me that the process today involved putting masking tape on the roof just outside the seal/edge of where the tape is. They taped it and when they removed the masking tape it peeled the paint off the roof in a couple of places - due they say to poor adhesion of the paint. So now it's got to go to a bodyshop to be resprayed. Awaiting details of what exactly they are going to do. I have solar panels (removable) and a brandrup isotop inner. This is attached with velcro at the bottom inside but at the top some pieces which I don't think are removable. Has anyone else had a respray with an interior isotop fitted? I know some folks have had new bellows - is this because they remove the roof to respray?
You can remove the top push in parts at the top. Use a trim removal tool such as contained this kit to release the securing strip.I took my T6 in today to have the tape applied. They checked it a couple of weeks ago, found no corrosion, but had no tape. They told me that the process today involved putting masking tape on the roof just outside the seal/edge of where the tape is. They taped it and when they removed the masking tape it peeled the paint off the roof in a couple of places - due they say to poor adhesion of the paint. So now it's got to go to a bodyshop to be resprayed. Awaiting details of what exactly they are going to do. I have solar panels (removable) and a brandrup isotop inner. This is attached with velcro at the bottom inside but at the top some pieces which I don't think are removable. Has anyone else had a respray with an interior isotop fitted? I know some folks have had new bellows - is this because they remove the roof to respray?
Quoting my own post to link in Loz's topic below - I missed this topic which covers exactly the above and others might have missed it too? Useful to have it linked here too maybe:
https://vwcaliforniaclub.com/threads/adding-the-3m-tape-to-roof-edges.24514/
It’s a tough one but if you don’t remove it I think they might well decline to remove/inspect it.I’m in a dilemma as I did exactly what Loz did this summer with the 3m tape from Viking, Cali is going in for some warranty work and this recall was mentioned. My issue is do I take off the 3m tape off before it goes in or leave it on the roof.
I have no corrosion on the roof and our Cali is July 2016
Any thoughts?
My thoughts - Taking tape off may not be easy and could possibly damage the paintwork, not covered by warranty as you did the damage. Not much point in taking the tape off just to have it replaced by VW.I’m in a dilemma as I did exactly what Loz did this summer with the 3m tape from Viking, Cali is going in for some warranty work and this recall was mentioned. My issue is do I take off the 3m tape off before it goes in or leave it on the roof.
Any thoughts?
Thanks everyone for the feedback, it's a tough one as for what's best . My gut feeling is to take off the tape, clean up and blow all the crap out of the seal.
Probably try a small part with a hair dryer as Max-Felix stated and see how easy it pulls off, not sure the dealer would take much care in taking it off if they offered to do so.
How are they coming from the factory now, the same as with the sealant around the seal or something different?
A little cheesed off to say the least!
Up until recently, the factory was applying tape but the body shop repair did not. I tried in vain to ensure that tape be applied to my repair at the end of last year but to no avail. So, communication between VW and the dealerships is as good as ever!Hi they are coming through just with the tape around no sealant at all which annoys me as we are instructed to follow the workshop manual to the tee and they factory doesn't.
