Keith Smith
Mine does the same, it will turn off while the Cali is coming to a halt, really unnerving at times.Our T6 turns off engine before van is halted if it is left activated. I usually keep it turned off.
I've not had that, but it is quick to switch off - particularly annoying when just pausing at a junction. It needs a delay of 2-3 seconds to confirm you have stopped.Mine does the same, it will turn off while the Cali is coming to a halt, really unnerving at times.
If you want it disabled automatically, plug in a 13 pin to 7 pin adapter into your tow socket. Of course, you won't be able to turn it on again without removing the adapter!
It is theoretically controllable (on the Renault) as it is possible to hold the vehicle stationary with a light pressure on the brake pedal - in which case the start-stop will not operate. Or with a heavier pressure on the brake pedal then the stop-start will activate.
Tried to have that done on my previous BMW but told that it's part of EU regulations to be fitted and cannot be turned off, by the Dealer. I couldn't even get the stop delay reset.Can't it be switched off by default through the computer?
Reversing Camera still works?If you want it disabled automatically, plug in a 13 pin to 7 pin adapter into your tow socket. Of course, you won't be able to turn it on again without removing the adapter!
There are some vcds tweaks for other VW vehicles that involve changing some default values deep inside, eg minimum voltage required to stop/start, which do not disable, but modify the way it works to the point it won't!Tried to have that done on my previous BMW but told that it's part of EU regulations to be fitted and cannot be turned off, by the Dealer. I couldn't even get the stop delay reset.
No doubt someone who can access the Computer by using a Laptop may find a way.
Unlikely as it will be part of the Euro 6 programming probably.Does anyone know if there is likely to be a VCDS coding to toggle the on/ off setting on the T6? I cannot find a security code that works yet.
I've noticed that I now automatically reach for the off switch just before I lift the clutch at the start of a journeyI guess it's less of an irritation on a manual vehicle as you can hold the clutch down to prevent it activating.
Manual 1 DSG 0
Normal function of the Stop/start function, you probably just never noticed it before. aircon during hot weather can have the same effect.T5 SE 180 - the stop start function error display kept coming on so took it on a last gasp warranty visit to the dealer - according to the technicians the function will disable if the battery level lowers to a certain point :- something that is quite likely in the off season when there is less use . Anyone else had that response ..? as many above I have started to turn it off at the beginning of every trip....
Previous BMW was the same as is the Wife's new Citroen. Asked the BMW Technician if the delay in switching off could be lengthened time wise but no was the answer.Start stop in my (2017) car is very aggressive and cuts the engine before the wheels have stopped turning; a real PITA. However, the Cali is quite polite and feathering the brake pedal controls it, as earlier described. Maybe they have “improved” start stop on the latest models!
