Erbster
I'm amazed the roof is NOT made of fibreglass. We wouldn't have this agonising if that were the case
T4WFA, I think you are correct.There was a good point made a few posts back.... Can't spot it now! It was suggesting that perhaps few owners have had main roof corrosion ACTUALLY rise up above the removable seal? Is that right? If it is, it maybe that it's all explained by the water in the (waterbased) paint trying to exit, when the seal is applied to still curing paint.
Wishful thinking perhaps, but if it were true, and could be fixed by properly baking a well executed repair before fitting the seal, things may be heading in the right direction.....
If vw have then filxed the front spoiler bit of the roof (from T6/very late T5, and with the encapsulation repair to older vans).... Even better.
I've obviously been taking hallucinogenic drugs. I'll take myself to A&E and await the destruction of my post.
Pretty sure it would weigh too much if made of simple fibre glass, it would need to be carbon fibre which would be much more expensive to produce than Aluminium.I'm amazed the roof is NOT made of fibreglass. We wouldn't have this agonising if that were the case
I know of two T6 elevating roof issues, both are corrosion behind the seal, not above it. i.e. the seal has been removed to see the bubbles. It is also true, to date, that no one has reported any issue with the front panel on a T6.
I am happy to be told otherwise.
I hope I don't speak too soon but it dose seem as if progress is being made - even if slowly! I have a vested interest in being positive about these issues as I am only a few weeks away from taking delivery of a new Cali. (Build Wk4)
JW
Yes, tempting isn't it!After reading Tomatoman65's post re the silicon grease, if I was picking up my new T6 I would be very tempted to remove the seal and fill it with silicon grease before refitting in an effort to avoid the roof corrosion issue completely. Once my T5 is repaired it will be getting the silicon grease treatment.
@snowy55, did your main (rising) roof corrosion (s) extend beyond the rubber and become visible (on the t5)?
The first time the raising roof was repaired the seal was filled with some kind of waxoil type fluid, maybe cavity wax, but the bubbling still reoccurred.
Also putting your own remedy in there could invalidate any future warranty claim.
Hi T6B, tomorrow is the day of inspection?Just been outside and we have it too on our T6 Beach
The rubber seal was quite tight but once budged the rest of it came away easily, we have several areas of small bubbles on both sides.
Inspection booked in for the dealer next Tuesday, they say I need to allow 2 hours!
Has nobody else checked ???
Can you ask them if they know what VW have done to fix the problem on the T6? Thanks, JWMy T5 is going to be inspected tomorrow, will advise what they say about warranty periods, repair guarantee and proposed repair method.
I think we all know the answer to that one.
Sorry, who is your dealer?
and the answer is: "what problem?"
Does anyone have an idea of the actual incidence of roof corrosion after say 5 years? Is it 5% or 95% etc.
I can see there is 375 on the poll saying they have it which is 375 too many, but curious how many Calis don't have the issue.
Good find! Looks pretty legitimate. Wow that is double the figure I had seen in a post somewhere on this forum of 2000 units registered.I found this website - apparently showing how many California's are registered in the UK - https://www.howmanyleft.co.uk/family/volkswagen_california - of course, the next question is what proportion of owners visit the California Club pages and see the polls! If they all do (and vote if they've had a corrosion problem), the incidence rate seems to be close to 9%. Given that surveys rarely get 100% response rate, it must be a deal higher than that.
It is amazing VW are not more motivated to find a solution, even if each repair only costs them £3k, 375 is still over £1M of profit they have thrown away. Even with the likely healthy margins the factory makes on California's, that's quite a lot of units shifted just to stand still.
Its a good point! I wonder if the DVLA called it something else? Its worth a question to the web site.I find this data puzzling, as I bought a California SE in early 2007, as did others I know. These figures show nothing presaging 2010. Am I missing something?
See Volkswagen Transporter CalifIts a good point! I wonder if the DVLA called it something else? Its worth a question to the web site.
Also Volkswagen Motor Caravan, https://www.howmanyleft.co.uk/family/volkswagen_motor_caravanSee Volkswagen Transporter Calif
Just made a trawl of the data - I make it about 9600 VW Cali variants currently licenced (Q3-2016) in the UK under various names.See Volkswagen Transporter Calif
