Keith Smith
We need to get things in perspective here, this is a shambles and VW should be ashamed of themselves but other manufactures have made vehicles that they knew were death traps and did nothing about it.
Agree, Vauxhall and the Zaphira.We need to get things in perspective here, this is a shambles and VW should be ashamed of themselves but other manufactures have made vehicles that they knew were death traps and did nothing about it.
I cannot answer your first question with any authority.2. The corrosion is cosmetic, but wouldn't be visible unless one where (i) standing up high somehow and looking at the roof (which is normally too high to be seen unless you're super tall), and possibly even (ii) doing that, while lifting a rubber seal or piece of trim?
I expect the tape will simply delay the corrosion issue to beyond the warranty period - it is not a cure.Given the scale of the issue I'm still gobsmacked that no third party has offered a solution, seal without steel in it, prep, respray and tape as apparently in the latest VW solution, or some other magic. I guess this is because not enough have fallen out of the 6 year warranty window yet.
Agree, but i think VW know but refuse to admit it.In my opinion and it is only my opinion the sooner these faults are reported the better VW might actually sit up and take notice that the T6 has got the same problem as the T5,
True but what will happen is that my van will be in for partial repair of the corrosion appearing now. It won't get any preventative work done and it means I'll probably have to keep going back every six months. Not really satisfactory to have to lose the use of my van regularly. I'd love to be able to tell vw but refuse a patch up remedy.In my opinion and it is only my opinion the sooner these faults are reported the better VW might actually sit up and take notice that the T6 has got the same problem as the T5,
Hi Andy, has the problem reoccurred following the repair with tape?Tape was put on the edge of lifting roof on my t5 when it had original fix. Done by independent large body shop.
Thanks for update.Very interesting that your Cali had no tape. Do you have a build date? My intel says this was part of a new procedure from early to mid Dec '16.Took the plunge and had a look at mine by removing the seal.
So far so good.
I got mine in mid January 2017 and no signs of any tape?
Seal was not fitted with any sort of sealant and was very easy to take off. Not that dirty underneath but worth doing.
Putting the seal back on again was slightly harder and is not in my view a very good design. Started at the front and worked round. As we all know the bit at the front where there is a kink in the roof is a useless fit, especially considering all the roof issues. No doubt it does its job as a seal to stop egress into the Cali but it is an obvious water trap.
I intend to keep an eye on mine and will clean and check every six months.
In January it will be going back for its annual paint check by the guy who did the detailing. I shall probably remove the seal and see what he suggests with protecting the rim.
Mike
So far so good.
Mike
Afraid I don't know the build date.Thanks for update.Very interesting that your Cali had no tape. Do you have a build date? My intel says this was part of a new procedure from early to mid Dec '16.
Certainly would. Hopefully you will identify the tape. If so keep us posted.May be worth thinking about getting the film added now below the bubbling starts? I am chasing VW for a part number or name for the product which is now described on the T6 parts list as 'protective film' see my post on the T5 roof corrosion thread. I will be fitting the tape as soon as the paint repair is done.
Anyone heard of 2017 California's out there with the same corrosion issues ??.
