Auberg-ine
Is it an office? Is it a lounge? Is it a camper?
If anyone wanted to return a T6 with roof corrosion, I'd just park it on the dealer's forecourt, push the keys through the letter box and instruct a solicitor. I think you'd get a pretty quick payout.
VW struggling to fix a defect that emerged on a previous model is one thing, but to have claimed to have fixed it on the late T5's, and then to have launched a new model with the same fault is totally indefensible.
I am starting this thread so T6 owners and potential T6 owners are made aware that the T6 is subject to roof corrosion.
Here are 3 photos taken underneath the seal on the raising section of the roof on a May 2016 T6 California Beach taken today after our first trip away in her. .
Our much loved 2014 California SE was unsuccessfully repaired twice, the blistering quickly returned and it was booked in for a 3rd repair. We just could not bring ourselves to go through this all again and we made the difficult decision to part exchange it for the 2016 T6 Beach, thinking the problem had been cured. But obviously not!
So, our 2014 SE has it (three times), a loan 2015 SE had it and now our 2016 has it - the roof issue is still the same.
Remember folks when your warranty is up you're paying for your own repairs.
So yet again, we can either look forward to going to the dealers to register a fourth warranty claim for roof corrosion and then to go on a never ending list for an ineffectual repair but instead we are going to return the vehicle first thing in the morning and demand our money back! (See Consumer Right's Act 2015).
We have also cancelled the new T6 Beach we ordered on the 26th March, 2016 which is yet to be built!!!
Another VW will never darken our driveway again.
Given that VW claim to have solved the roof corrosion problem, I'd like to think they would have enough confidence in their solution to back it up with an extended warranty on the whole roof (as with the T5) of 6 years.I believe the 3 yr Extension was in relation to the Front Panel over the Windscreen. Could be mistaken. Anyway, that problem was supposed to have been fixed in MY 2015 with a change in the alloy composition - apparently, hence the original repair being the replacement of that whole panel.
Oh really? How would, say a DIY averse (read incapable) chap, go about that?That would be quite any easy self fix..
You can purchase the 3M "Bicycle Tape" from Viking Tapes. Wait until the warm weather return.. pull off the seal from the edge of the front cover, remove the old tape, clean up with isopropyl or similar them apply the new tape and replace the seal..Oh really? How would, say a DIY averse (read incapable) chap, go about that?
All the best
After 18 months of trouble free ownership I noticed this last week. Worth checking yours if you have the protective strip installed from the factory which I think is most T6’s. It’s in with Tonbridge (who have been excellent generally) for warrantee repair. They have advised that it needs to be sent to a body shop. Does anyone know which body shop in the south east has the best reputation for fixing roof issues?
All the best
Same thing has happened to mine. Passenger side?
Thanks Stoneybroke on no. 3 That final sentence is a cause for concern - is there an expected time that a vehicle is expected to last then do you think?
Anyone able to chime in on no.s 1 & 2?
View attachment 36572 View attachment 36571
Finally able to get roof and have a look at the tape sticking out.
The tape is 12 mm wide. Can only find 3M tape 25 mm,so will need to use a craft knife to cut it to size. Not much needed.
Husband happy to do this as per Loz instruction rather than let a body shop mess with the roof.
Hi Everyone,
On hearing of the recall recently announced on the roof issues, I booked my two and a half year old Cali in to be checked and have tape applied if no signs of corrosion.
Low and behold.. a couple of spots were found so booked back in for repair. I was told it’s a local touch up if corrosion can be dealt with below the seal line. If not it’s a specialist job???
I have now been told that it is possible that mine is possibly ok for a local fix and is now booked back in.
Over the weekend I completely removed the rubber seal and checked to found several tiny bubbles starting all around the roof. Not just outside of roof but a couple of places inside. All within an inch of edge I think.
It raises more questions with me now.....
The tape is that, just tape... there are areas not showing any symptoms of the fault but being a design or production fault.. the fault still lies beneath, it may be delayed a bit now with tape.. but still there to break thru as and when, maybe 5 years down the line.
I am no metallurgist or out like that but when you use electronics to apply paints you create charges to attract the paint powders. Introduce alloys with steal and you have now built one dirty grate confused capacitor that may not be too happy with its new coat...
Something like that anyway...
I will keep all posted as it goes on.....
My T6 was the same build date as your,s They have told me when I collected from my 20.000 service that it has to be in for new tape to be fitted as it is a recall job. they need it for 24hr for the adhesive to cureMy suspicion is not eating at me and as I am one of the "don't look" until nearly 3 years has passed I will not confirm or otherwise that suspicion.
The converters all use GRP, that material is invariable quite thin to keep the weight down so can suffer from cracking/delamination and other faults, you pays your money etc.Hi, I'm thinking of buying a secondhand camper, is this corrosion problem only on VW's conversion, Is it the case with third party conversions?
I also have the Cambee conversion on my radar would this still be a problem/
