Meoncoast
A Beach at a Bay,
share investment in Millers oil may be the only good bet in this 180 issue.
All very correct and hard to argue with, except you are ignoring the other data available : photos showing the worn bores and congested piston rings, the decayed internals of the egr cooler and the high Al and Si contents of all the analysis being ordered.I think it could be helpful to step aside from the specifics of this case for a moment, to create a better understanding of oil usage generally . Apologies in advance since I know that many/most will already know the following.
On the subject of 'excessive oil consumption' in general there are many possible contributing factors, however, there are really only two common root causes for oil consumption (albeit not necessarily 'excessive'):
If you suspect excessive oil consumption then, if you can rule out external leaks, the most probable cause - by default - is combustion.
- Leaks - engine oil is getting past seals/gaskets/finding unexpected routes/holes etc. and is 'lost'
- Combustion - engine oil is finding it's way into the combustion chamber (see leaks) and being burned with the fuel and/or ejected with exhaust gasses.
By design, internal combustion engines [that use oil for lubrication] will consume some oil in the combustion chamber. It's the 'how much' that is important and, of course, this varies according to engine design, manufacture and usage. However, put simply, the primary reason is that the cylinder walls are separated from the pistons by a thin film of engine oil; the piston rings act as the gasket/seal in this case but they do not form a perfect seal - some oil is left on cylinder walls during the combustion/exhaust cycle and is consumed. A similar but secondary situation exists between the cylinder head valves and seals.
In a modern, well-designed & manufactured engine using modern oils, engine oil consumption of this type can be very small - effectively unnoticeable between oil changes (if checking by use of the dipstick alone). That is not to say that you do not need to check oil-levels between changes - certain uses and environments can temporarily increase oil consumption, for example, high temperatures, high revs, high load, excessive engine braking, wrong type/wrong viscosity of oil for conditions, etc.
Disregarding external oil leaks and the temporary causes just mentioned, excessive oil consumption indicates that there is an oil 'leak' into the combustion chamber. N.B. This does not necessarily mean the piston ring/cylinder wall seal: oil could also get into the combustion chamber via other routes. For example, via valve seals (as already mentioned), via air intake (besides the EGR system, most engines employ some form of positive crankcase and/or valve cover ventilation back to air intake*), via cylinder head gasket failure.
*High pressures can force oil (in liquid or vapour form) back into the combustion chamber via this route; this effect can be exacerbated in high compression (e.g. diesel) and/or forced induction (e.g. turbo) engines and/or where failure of a gasket/seal, leads to over-pressurisation of the crankcase/valve covers/turbo oil-ways/etc ...
So, back to the specifics of this case: for affected vehicles, the remedial action taken by VW (as documented in the relevant TPI) would suggest excessive oil consumption through failure of the piston ring/cylinder wall seal. In my opinion, the associated discussion (here and elsewhere) speculates as to the cause of that seal failure.
How many miles you done Mark? That level of Al is alarming.Got the results of my oil analysis today. Not good! Very high levels of Iron, Aluminium and Silicon. No oil usage as yet. I spoke to the guy at Millers about it. He said he had done a lot of these samples for 180 T5s over the past month or two and that only 2 or 3 had been within acceptable limits. Most, like mine were miles above!
All rather worrying! It seems probable that nearly everyone with the 180 engine is likely to find they have high levels of Fe, Al and Si if they get their oil tested. From there is seems fairly inevitable that at some point it will turn into high oil usage and then engine replacement! The mileage at which it happens seems to vary quite a lot but the end result seems pretty consistent i.e. new engine! Just have to hope the good work from the guys on the Facebook forum / t5-life.com spurs VW into some sort of action before it happens!
I'm not claiming these as proof of cause, but they are seem specific to the 180hp engine which is the one developing the problems. It would be odd to ignore them.
I've done 47,650 miles in total and just over 11,500 on that oil.How many miles you done Mark? That level of Al is alarming.
I can understand that there are plenty of sources for the aluminium, but where else could the Silicon be coming from? It's usually just trace amounts in oil. Apologies if I couldn't find a previous explanation in the thread."the decayed internals of the egr cooler" is interesting (and worrying!); it is also a possible source of "the high Al and Si contents of all the analysis" but it is not the only source - there are, of course, many other sources for those elements (as contaminants) in the oil: silicon has already been mentioned in a previous post; aluminium (especially when alloyed) is a very common material for engine component manufacture (in this context, two obvious examples could be the cylinder head and pistons).
Yes clearly the aluminium could come from the pistons, and the silica from dust, but those apply to all engines and all expected oil samples. My point (and criticism) is you are looking at generic engine wear, where the issue isn't generic, and specifically seems linked to an engine which uses a particular type of egr cooler construction, that has proven to be disintegrating (sometimes), has been upgraded several times (/D etc).In case my position needs clarifying:
Based on the posts I've already made to this thread, I think it's unfair to just suggest I'm ignoring anything; my purpose (apparently failed) was to inform and broaden discussion.
- "photos showing showing the worn bores and congested piston rings" would actually confirm what was suggested in my last post
- "the decayed internals of the egr cooler" is interesting (and worrying!); it is also a possible source of "the high Al and Si contents of all the analysis" but it is not the only source - there are, of course, many other sources for those elements (as contaminants) in the oil: silicon has already been mentioned in a previous post; aluminium (especially when alloyed) is a very common material for engine component manufacture (in this context, two obvious examples could be the cylinder head and pistons).
Your points aren't incorrect, they are just looking at a generic situation, where this problem is specific.
1 EGR cooler.All very correct and hard to argue with, except you are ignoring the other data available : photos showing the worn bores and congested piston rings, the decayed internals of the egr cooler and the high Al and Si contents of all the analysis being ordered.
You have pictures of 1 EGR and 1 Engine and 400 members of the Facebook group but NOT 400 members who have the same problem with their engine. Evidence not Supposition is what is needed. The fact you have a Facebook group and now a Forum is NOT evidence.Go to www.t5-life.com and you will see pictures of a failed EGR internals, and bore scoring because of the failed EGR.
We have over 400 members on the FB and growing fast so have now set up a dedicated web page to discuss and keep track of this situation.
It's funny though as soon as block off the EGR and DPF and do a remap all the problems seem to disappear, funny that no more elevated high metal wear in the motor..... hmmmm I wonder why.
I wonder why as well. The DPF is downstream from the engine, so can have nothing to do with the problem and by disabling the EGR and DPF and reprogramming the EMS you are basically turning your vehicle into an environmental hazard, maybe not to yourself but to others. Good one.It's funny though as soon as block off the EGR and DPF and do a remap all the problems seem to disappear, funny that no more elevated high metal wear in the motor..... hmmmm I wonder why.
