sbmcd
D
do you have any pictures of the seal bonding work carried out?
There is nothing to see from the outside, I think I will add sealant round the top edge as an additional measure.
D
I've been running a configuration this lunchtime and did notice this which seems a move in the right direction (ie at time of manufacture) at least, but only on Beach?:View attachment 38722
1st April maybe?@Borris @Jabberwocky - apologies forgot to follow up, it has seemingly gone off the configurator now.
Chased up a VW tech at my local dealer and apparently it went live on the config' too early - not scheduled for an option until end of first quarter 2019?
I have to say I am not entirely surprised by this water retention. Thermal cycling will have caused water ingress/condensation in any area where air is present that is not sealed. As for it drying out, well, water under a "seal" does not see much, if any, air movement and consequently will not evaporate. Hence the roof edge, with or with tape will be in a permanently wet environment. Must be a design feature.Fresh out of my garage this morning, I thought I’d get the top up and clean under the back of the seal. It looks like there is constantly water within the seal. The van hasn’t seen water for nearly three weeks.
I take the seal off now every time ive used it, fill up the cats water bowl with it and then dry it on the radiator. Missus isn't very happy thoughI have to say I am not entirely surprised by this water retention. Thermal cycling will have caused water ingress/condensation in any area where air is present that is not sealed. As for it drying out, well, water under a "seal" does not see much, if any, air movement and consequently will not evaporate. Hence the roof edge, with or with tape will be in a permanently wet environment. Must be a design feature.![]()
Can I ask what it's manufacture month was? We are Dec and I think ours is OK but we will find out soon.Just had my T5 checked and it needs to go into the Body Shop for fixing apparently. I'll get that booked in and see what happens.
Think it's time to buy shares in bodyshops. They'll have to double capacity to handle all of our roof corrosion this workshop action is going to find.Just had my T5 checked and it needs to go into the Body Shop for fixing apparently. I'll get that booked in and see what happens.
As your Cali is only 11 months old, (Build - November '17), I assume your roof has the tape already fitted by the factory. Can you confirm please?I received confirmation yesterday, I will be having a new seal fitted due to issues with rust at 11 months old....
Yes it has (except for the front section for some unknown reason).As your Cali is only 11 months old, (Build - November '17), I assume your roof has the tape already fitted by the factory. Can you confirm please?
It doesn’t take long to look and treat/prevent any permanent damage.Thanks. Yes, its a bit of a mystery why the front section has not got the tape. I wonder if the earlier, but after Dec '16, fix had the tape on the front section. Must be brave enough and look! (although my leaning is still towards "leave it until just before expiry of warranty then look").
Not so. Checked at 3 years - Clear. Will be checked this December year 4 and have the fixed carried out.It doesn’t take long to look and treat/prevent any permanent damage.
You could ignore for now but you will most probably be without a van for a long while while they patch it up in the future if it’s discovered to have calirot.
I'll take my chances all the same.It doesn’t take long to look and treat/prevent any permanent damage.
I’m sure there are many with no issues just like yourself. However from my point of veiw I am a little more apprehensive after the discovery of rust at such an early age.Not so. Checked at 3 years - Clear. Will be checked this December year 4 and have the fixed carried out.
I never checked until my last service at 3 years.
Understandable!I’m sure there are many with no issues just like yourself. However from my point of veiw I am a little more apprehensive after the discovery of rust at such an early age.
