That’s for the gold plated one!Their £778 is Cambelt and Water pump. They have now offered to do it for £700 but still fail to say if that includes VAT!
Following your link gives £458 (£382 + VAT) for cambelt only and £917 (£765 + vat) for cambelt and waterpump.
On your 5 pot is there a service/replacement interval, miles or time, for a water pump change ?I can recommend
4.7 on Google reviews. Fairly near you. 6 miles?![]()
Peter Norris
www.peternorris.co.uk
I’ve used them for my Golf and Cali for about ten years. John on the front desk has always been very helpful and I trust them. With a 5 cylinder T5 I’ve never had a cam belt changed though. All cogs.
SMG Croydon once quoted me £1000 to replace the £18 water pump in the wardrobe. Not been back.
My Golf got a cam belt at 6 years and 20k. John probably thought I was mad. It’s now 14 years old and 45k. Maybe next year…if I don’t sell it and get an i3!
But they include a physical inspection of the cambelt at each service, if not annually. VWUK do not specify this as part of the service.According to VW Europe, cambelt change is at 210,000 Km with a recommendation at 5 years if this comes sooner.
Automatic gear box.What do you mean by DSG ?
Just read some and familiarised myself with the tech aspect of ‘double clutch’ etc of DSGAutomatic gear box.
To clarify there are 2 water pumps here.On your 5 pot is there a service/replacement interval, miles or time, for a water pump change ?
Of all the vehicles I’ve owned, some exceeded 200,000 miles I’ve not had a water pump failure or leak on any of them.
Did my cambelt with a good local independent. Saved over £100, all the right paperwork so service history is intact.A bit of a shock when I contacted dealership as 1) Glasgow , they didn’t mention Cam belt and when I did they said £500 extra for that. 2) Edinburgh did mention Cam belt at 4years but again an additional £500 on top of ‘full service’.
I didn’t realise how expensive it would be … haven’t decided yet whether to use Glasgow or Edinburgh !
Different engines, different cam drives, belt v chain and different water pumps.To clarify there are 2 water pumps here.
First, the engine one which is good to change when you get get the cam belt done I think as it’s easy to access at the same time.
Second, the water pump for the California fresh water system. The latter is what failed for me after 8 years.
I’m fairly certain I’ve never replaced the former. Presumably if it fails it won’t trash the engine like a belt could. Although I’d be interested to know if I’ve got that wrong!
I tend to feel the T5 engine is pretty great if you plan to keep your California a long time. Cog driven with less maintenance items and my sealed for life Auto. No adblue etc. Mine gets an annual service by Peter Norris and so far mechanically nothing has failed. Just one dpf sensor I replaced myself for about £20. Just done 50k miles though.
Of course the roof has recently leaked. Now fixed. And the roof sensors failed. Now fixed. I’m very fortunate to have only minor bubbling on the roof and have chosen to leave well alone.
No auto boxes are sealed for life. That is the VAG company line. It is probably a Borg Warner box but Audi stated the same with the ZF auto (sealed for life). ZF actually state that oil change is advised at 80k miles. I don’t know what the manufacturer of you box state but probably the same.To clarify there are 2 water pumps here.
further to my previous post, regarding the cost from an independent VW approved garage, local to me, i asked several other questions:So following this thread I enquired into the cost of cam belt / water pump via a recommendation on this site, the supplier is an indi whom is local to me and is VW approved.
here is there response !
either VW have made a mistake or they are taking the rise ?
“Thanks for your enquiry. Good to hear of recommendations!
Cost to replace the cam belt and water pump is £560. Cost to replace the cam belt alone £400. We always recommend replacing the water pump when the cam belt is replaced.
Prices include parts, labour and VAT.”
Amarillo, Pm me if you want the detail of the company, you could have a day out and save a fortune!
I think the main reason to change the water pump is the cost of labour-it’s the same work as getting to the camshaft belt.
Yes it’s not causing any problems. I like the bit about magnets. I presume this is a similar concept to the thing attached to the bottom of my combi boiler. Collects any metal debris.This is from Blauparts in the US. Details for the gearbox change and recommended intervals. Might be able get it done at Toyota as they also used them.
If it’s not having issues or making noise, I would be inclined to leave it too.
Had the same with an Audi with the Tiotronic gearbox. Audi said it was sealed for life but there’s a really good company in Glasgow who do the oil change with special equipment which can flush the torque converter. The trouble with ZF one was the material in the torque converter was affected by water which built up over time in the oil.
That’s the theory of the water pump change with the cam belt, although from what @Amarillo has shown the cost of the water pump via a dealer is exorbitant Now compared to what it used to be, which negates any benefit of carrying out a water pump change at the same time as the timing belt at 4 / 5 years as suggested by VW.4 years is a very short time for a cam belt. Water pump should last longer than 4 years as well. Is the water pump something that you change due to the cost of changing it if it fails. Extra £50 to add in the water pump change.
Just had confirmation of cost via VW dealer :That’s the theory of the water pump change with the cam belt, although from what @Amarillo has shown the cost of the water pump via a dealer is exorbitant Now compared to what it used to be, which negates any benefit of carrying out a water pump change at the same time as the timing belt at 4 / 5 years as suggested by VW.
Can you advise which dealership please ?We have been quoted (and agreed to) £599, inc of vat for Cam belt and Water pump from VW commercial dealership.
I agree mine booked in for 6 year service next month and only brake & aircon mentioned by Dealer as required. I did the DSG myself last summer but added Haldex to next month Dealer service myself.Don't rely on the dealership mentioning cambelt and DSG oil changes - mine didn't. Its possible they would have eventually but .....
I thought the DSG oil change interval was based only on mileage.
Snatch their hands off, we paid £750 for same in November at VW main dealership.We have been quoted (and agreed to) £599, inc of vat for Cam belt and Water pump from VW commercial dealership.
In Germany, cambelt is 210,000km (131k mi), no time Limit. So if you drive 13k mi a year you‘‘ll replace cambelt and water pump after 10 yrs. Same goes for other brands and models, always mileage dependent, not time.I know my cambelt is overdue according to VW(UK) servicing schedule, but I think VW(Europe) recommend a cambelt change every 210,000 km irrespective of time.
This website suggests 210,000km and a recommendation of every 5 years.
When to replace a timing belt in the VW Transporter T6? All intervals
When to replace the VW Volkswagen T6 timing belt? All intervals. Both diesel and petrol engines. Including 2.0 TDI and TSI. Check directly >autobaak.nl
Even some VW(UK) websites suggest every 5 years for post 2009 cars.
VW Cambelts Frequently Asked Questions | Volkswagen UK
If you reach the recommended mileage limit before 4 or 5 years, you may need to change the cambelt sooner. Get in touch with VW if you have more questions.www.volkswagen.co.uk
I am trying to get SMG Tonbridge to price match Lookers Guildford £432 (inc). If they won't I'll go to Guildford.
Tonbridge is a 40m drive, Guildford is 70m.
Tonbridge is a 5m cycle ride and direct train home.
Guildford is a 20m cycle ride and two trains home.
Obviously I'd prefer Tonbridge to price match, but a £300 saving cannot be ignored.
