DM
PS. Why did you need a new seal?New seal fitted on the roof today and notice 2 small bubbles on the front edge, nothing to worry about the dealer said... just keep an eye on it.... oh yes i certainly will!
If the bubbling paint was in the middle of the bonnet would you have accepted the advice "just keep an eye on it"
No you wouldn't, you would be thumping on the desk and demanding an immediate respray.
Why accept anything different because it's the roof?
Go back, get the roof photographed and get the claim process started.
With any luck you might get it repaired by the end of the decade!!
Agreed, i would not accept it on a £6k Kia let alone a £60k Cali, I am stunned at the amount of people just happy to live with this in the hope that others will fight the cause.
But I think that is a totally unfair comment. The California comes with a 3 year warranty. This problem is cosmetic rather than destructive. VW can repair it and , according to some who have T5s with this problem, less than perfectly. So, check early, less than perfect repair or recurrence, battle with VWCS and the body shop.
OR, wait until the 3 year warranty is almost up and then check and get it logged on the system. In the meantime enjoy.
It may seem selfish to you but in reality it is just being practical and pragmatic about this problem.
After all. The roof on the T6 is exactly the same as the T5 and has exactly the same problem on the Elevating Section. If VW haven't accepted there is a problem on the T5 and instituted a proper fix, as they apparently have on the T5 Front Roof section, then the same will happen on the T6.
I haven't looked on mine yet, 2014 model, and won't until it has its MOT and service before the warranty is up. If I have the problem then I might have it sorted by a body shop that specialises in Aluminium bodywork rather than a body shop that deals with the main manufacturers at the lowest price/repair.
In the meantime I enjoy this amazingly versatile vehicle.
Unfortunately That's life. VW haven't accepted that there is a problem on the Elevating Roof section on the T5 so join the club.If all T6 owners had this point of view we would not know about the problem for another 3 years, at least the ones who have checked early have got things moving with VW because as far as they are concerned the T6 does not have corrosion! The more of us that check and report the problem will get VW to listen and find a solution. As we know the original repair is failing already so we need to pressure them into finding a fix.
Yes it is only cosmetic but I saved for ages for my Cali and this is so disappointing.
Be cautious and consider......Please read the warranty carefully. The second bullet point brought me up short when I read it. My interpretation of this is that if you "detect" a fault and report it later rather than sooner you may not be covered under the paintwork warranty.We unfortunately have the small bubbles under the seal on the elevating roof aswell. Ours is a March 2016 T6 Ocean
I will write to VW to find out our position concerning warranty periods. At present I tend to agree with Welsh Gas on waiting until the warranty has nearly expired and then claiming as I don't think the current fix addresses the issue but just makes it look better (until it reappears again!).
I'd obviously prefer (as we all would) that VW admit there is a problem and then fix it - after all it's not a cheap vehicle.
However we'll continue to enjoy this amazing vehicle. We've had 10 mini adventures over the last year and as everyone says... 'wish we'd purchased one years ago!'
I'm with you.And why I am not looking until about to have it's 3rd Birthday
VW are supposed to undertake a Corrosion Check as part of the Service. I have had 2 Services and No Mention of any roof problems.Be cautious and consider......Please read the warranty carefully. The second bullet point brought me up short when I read it. My interpretation of this is that if you "detect" a fault and report it later rather than sooner you may not be covered under the paintwork warranty.
It says: (Their web site)
"Paintwork protection
Your vehicle warranty covers any manufacturing defect in paintwork, starting from the date of registration, for a total of three years.
Paintwork defects can be fixed free of charge under warranty if:
- You report the defect to a Volkswagen Van Centre within your warranty period.
- You tell a Volkswagen Van Centre about the defect as soon as you detect it to ensure there is no further deterioration.
- The defect was not caused by external influences such as accident damage, industrial fallout or pollution or insufficient care or maintenance."
That's a novel strategy (delaying tactic?) by VW! They don't look as if they're meant to be stuck down- has anyone found one that is stuck down as opposed to a bit sticky with all the muck that gets underneath?We are due our interim 12 mths service(part of 4 year service plan) on our T6 Cali . Our local VW Snows Plymouth say they have been told not to remove the roof seal round the lifting roof because it's stuck down. Advised if we removed it we could cause damage .
We are inclined to wait & have a look once VW finally find a solution .......
It is not stuck down. Parkway had no concerns removing mine today to inspect.That's a novel strategy (delaying tactic?) by VW! They don't look as if they're meant to be stuck down- has anyone found one that is stuck down as opposed to a bit sticky with all the muck that gets underneath?
Ask them for that advice in writing so that you have a copy to present in Court when the inevitable happens as they will be unable to carry out the detailed Corrosion Check as they are supposed to do in line with the Service Schedule. Bet they change their tune.We are due our interim 12 mths service(part of 4 year service plan) on our T6 Cali . Our local VW Snows Plymouth say they have been told not to remove the roof seal round the lifting roof because it's stuck down. Advised if we removed it we could cause damage .
I wonder what the 'detailed corrosion check' covers. Clearly they can only do a visual inspection of accessible areas. Hypothetically - if the seal is not removable then they cannot inspect under it - therefore the corrosion does not exist until it is so great it 'escapes' the seal. Maybe after the warranty has expired.Ask them for that advice in writing so that you have a copy to present in Court when the inevitable happens as they will be unable to carry out the detailed Corrosion Check as they are supposed to do in line with the Service Schedule. Bet they change their tune.![]()
In the service booklet it says the following (picked out from amongst other detail points):I wonder what the 'detailed corrosion check' covers.
But as my earlier post, Parkway had no concerns about removing mine today.
According to Parkway one of the criteria is that repairers must have specialist extraction equipment for working with aluminium.Agree Welsh Gas.
I'd also fit a 3rd party seal if there was one available - especially if it had plastic rather than steel reinforcement. In fact if there was such a thing I'd fit it today.
Anyone out there with any knowledge about automotive seals? Could be a nice little earner.
